Firmware update for ARLO PRO battery drain
I see there is a ‘fix” for ARLO PRO fast battery drain on SEPT 26..when I go to my acct and try to update my firmware , it says “no update available “ BUT my firmware numbers do NOT match the new firmware update in the announcement of a fix????? HELP???PLZ?? My husband is about ready to throw in the towel on these cameras...Kathleen
Try restarting your base. If you don't get a prompt to update, reinsert the camera battery. If THAT doesn't work, remove the camera from Settings, My Devices and resync.
So...I guess there is no way to do this remotely as I am not home???
You can restart the base remotely (Settings, My Devices, your base, Restart).
