Firmware 1.14.1.1_2913_78b189a and Smartthings integration
Looks to be an issue with triggering cameras to record with the current firmware version. Anyone else having the same issue where you cannot trigger a camera to record with Smartthings?
I have the same problem after installing firmware 1.14.1.0_2909. Have contacted customer support.
Good luck with that Eirik! Please keep us posted.
I agree that this needs to be addressed QUICKLY by Arlo. This is the time of year most people want to install outdoor security cameras to catch porch thieves. I had a motion sensor (non-arlo) placed to trigger my cameras. Now I can't do that and my weak Arlo camera motion sensor doesn't trigger when people approach my house. Word is getting out that Arlo is no longer compatible with Smartthings the way it was "intended and marketed".
I'm looking at returning my system to Best Buy and going with Lortex. I may loose the Smartthings integration, but have one system that works well on its own.
I have returned my system and got my money back. Now it's a case between Arlo and the online store. I bought the system back in september 2017 in Norway.
