My feed has stopped updating. Another post says that this has been fixed by an update but I have updated and still have the issue. I can only view feed when I restart my phone. I can’t do this every time I want to check my feed. Whereas I still get recent notifications, confirming the cameras still work, when I check feed I just see the spinning wheel with no recent updates.
What model phone?
Does force-closing and then relaunching the app also restore normal operation?
What model phone?
I’m using an iPhone 17, force closing & relaunched by the app does not fix the problem. So far only shutting down & restarting the phone seems to temporarily fix the issue. I’ll one new notification from the camera & it will appear in the feed but from the next notification onwards it will not show in feed until I restart phone. So I can have 6 new notifications but only see the most recent in the preview & none will show in the feed.
@DannyUKuser are you still seeing this same behavior?
I’m no longer having the issue 🤞I logged out and in a few times, seems to have fixed. Thanks
Well I’m still experiencing the same issue on my iPhone 16. No updating in feed regularly. Need to back out, close the app, open the app. Works for a while then dead. Can view live camera but not updating. When using history the little spinning wheel continues with no resolution. Too many times restarting the app.
@101Airborne have you tried to delete the app off the iPhone. Not the remove app but delete it off and then install it again.
I have an iPhone till yesterday everything worked fine but now I get a message to subscribe feeds which was never before
I have 14 pro I am seeing only subscription ad on feed window. I deleted and reinstalled still same.
Can you please send a screenshot of what you are seeing?
I spoke too soon. I have been having this issue again & now constantly have to log in and out to see an update feed. It’s have uninstalled & reinstalled the app but still get the issue.
Can you see if there is a new firmware available?
I haven’t had any notifications about new firmware being available & I can’t see any reference to this on the app. I would have thought that reinstalling the app would upload the latest version?
Can you send me a screenshot of what you are seeing under feed?
