False alerts when arming system.
Everytime I arm my system I get about five motion alerts at about 5 Seconds Apart. Each video I view shows nothing and I've noticed this is every time I've arm the system. Any ideas? Looks like I will have to roll back to the older app that was flawless.
Yes, it happens here too ( S7/os8.x )... only when arming I get 2 or 3 push alerts , but NOT every time.
It's the app and not much to be done till a new version comes out.
Rolling back is possible , but only if you have very good tech skills and the older app.
It does seem quite a bit to roll back. I'm pretty good at Tech but don't think I want to go through the whole thing and fix any problems that happens or may arise during a rollback. There seems to be a lot of complaint with multiple problems with the last 2 or 3 updates. I am just hoping that Arlo or Netgear is reading these forums and hoping to fix the problems ASAP. I guess I can put up with the problem for now. But the multiple notifications is just one of a handful of problems with this app.
I'm running version 2.5.3_22376 and have no issues at all. To install an old app on android is very simple, just a few steps. After you download the Arlo install from apkmirror, copy it to your phone (copy to downloads forder), then.....
- Use the my files app, goto the download folder, Tap on the APK file of the App you want and hit Install.
- Android Oreo now presents you with a popup option which gives the External Sources option.
- From the Install other apps menu click on the app you want to enable access.
- Tap on the switch next to Trust app from this source.
Wow! Thanks for giving me a how-to to install an older version. Never heard of apkmirror. It's a good site. I've rolled back and so far so good.
