Have somebody made/look into using a external powerbank outside to constant power the camera?
A bank who has higher capacity then the built-in battery? Maybe then get a year of power, atleast increase the time?
It’s been done with some success...
l’ve run a pro cam for a good amount off a gell cell ,6v/ 7ahr .....
it all depends on your needs
The clima here is maybe 10-20 celcius degree summer time and +5 to -10 Celcius degree winter time.
I don’t want to use a lot of money and then replace the battery to ofte, 3 times per year is properly ok, but not much more...
I
I
