EOL if I subscribe can I have more than 5 cameras?
I have arlo pros and bought some essentials with the discount and will subscribe come April, will I be able to have 5 pros & 5 essentials on the same account/base station or just 5 total? If not, can I just get 2 base stations and make that work or no?
thanks
@Phelps wrote:
will I be able to have 5 pros & 5 essentials on the same account/base station?
Yes. Though the base can only handle 5 simultaneous streams. If that's an issue for you, you can either get a second base, or shift some of the essentials to connect to your home wifi.
