  • 1 Reply
  • 617 Views
Phelps
I have arlo pros and bought some essentials with the discount and will subscribe come April, will I be able to have 5 pros & 5 essentials on the same account/base station or just 5 total? If not, can I just get 2 base stations and make that work or no?
thanks
@Phelps wrote:
will I be able to have 5 pros & 5 essentials on the same account/base station?
Yes.  Though the base can only handle 5 simultaneous streams.  If that's an issue for you, you can either get a second base, or shift some of the essentials to connect to your home wifi.
