After installing a few Arlo Q camaras I installed a base station and a few Arlo Pro wireless camaras, for some reason it keeps knocking me off the internet connection and the wifi goes down whenever I try to pull up any of the Arlo Pro camaras.
I installed a new Netgear router that is compatable with the Arlo Pro camaras and still have the same issue with maintaining an internet connection for the wifi.
Some folks have reported issues with the base near the route. Try moving the base further away using a long Ethernet cable or WiFi extender. It might also be worth trying a reset on the base and starting fresh.
