Does the arlo pro have continuous event recording yet?
  • 1 Reply
  • 2099 Views
dahemmi
I have bought the Arlo system recently and am very unhappy to find there is no setting to continue recording until motion ceases, I am discussing with the store I bought it from my intention to return it- which is proving somewhat difficult. I am happy with everything else with this system, but for me this is an unredeemable design flaw for a security system. I can see discussions about this feature having been implemented but then removed due to bugs in the Arlo Pro. Is it available in the Pro yet? If so I will attempt to trade up to that model.
migman_2001
Luminary
Luminary
The feature you are describing I do do use. However, there does need to be continuous movement to keep it functioning, otherwise the recording ends. There is about a 30 second reset period assuming there is new motion. for recording to resume again. And I belive that it only goes up to 5 minutes max record time, assuming there is continious movement during this time.
Overall, the system performs well as designed and within its intended specifications.
