Do the Arlo Pro cameras have a direct URL to get a snapshot?
  • 4 Replies
  • 6792 Views
rickengle
With other web cams I've used there is a URL syntax that can be used to directly access the camera to get a realtime snapshot, encoding the login in the URL?  Can that be done with the Arlo cameras?  I wanted to be able to include a snapshot of what a camera is seeing on a web page.
Thanks for any info on this,
  Rick
At least via the Arlo software, no. Whether you could somehow pull it off with IFTTT, SmartThings, whatever is unknown.
rickengle
OK, I wouldn't have wanted to use the Arlo software anyway, but rather a URL that you could plug directly into a browser that brings up a direct camera image.  Similar to how the snapshot images from cameras are accessed from https://arlo.netgear.com/#/cameras
  Rick
Again, answer No
rickengle
Ok, worth a shot.  Its good I have other cameras that are more open that I can pull the images from for now.
