With other web cams I've used there is a URL syntax that can be used to directly access the camera to get a realtime snapshot, encoding the login in the URL? Can that be done with the Arlo cameras? I wanted to be able to include a snapshot of what a camera is seeing on a web page.
Thanks for any info on this,
Rick
At least via the Arlo software, no. Whether you could somehow pull it off with IFTTT, SmartThings, whatever is unknown.
OK, I wouldn't have wanted to use the Arlo software anyway, but rather a URL that you could plug directly into a browser that brings up a direct camera image. Similar to how the snapshot images from cameras are accessed from https://arlo.netgear.com/#/cameras
Rick
Again, answer No
Ok, worth a shot. Its good I have other cameras that are more open that I can pull the images from for now.
