  • 4 Replies
  • 3130 Views
ConnieGarcia
Actually yes....
as a matter of fact , I find the Pro to have better night vision over the Pro2
ConnieGarcia
Ok! Thank you. There seemed to be an issue with speed, pixelation, and freezing. I’m currently wondering if I need more internet speed or better position.
Well. tho Arlo recommend at least a 1MBS upload, ( that is for the original Arlo cameras ) , the newer cameras like the Pro/Pro2 use a bit more data thruput.... I would say for really good response at least almost 2MBS upload for good response.  Some people are limited by their service so it may be an issue
I run 14 cams right now ( Arlo, Pro, Pro2, Baby cam, and Q ).... but have very little issues due to a very high upload speed.
Remember that when a cam is streaming, it can use 500Kb to 1 Meg ( depends on cam and level of quality )... and that is for each cam that becomes active if someone moves thru multi cams
ConnieGarcia
Thanks for all your advice. I’m not sure what internet speed I have but will call and check.
TY
C
