Do Arlo Pro Wire-Free cameras work with my existing Arlo base station?
  • 3272 Views
  • 2 Likes
g33k3r
From other posts I have seen that the Arlo Pro will sync with the original Arlo Base Station. I have not it explicitly stated that the audio functionality in the Arlo Pro are supported with the original Arlo Base station.  Are the Arlo Pro voice capabilities supported with the original Arlo base station?
Am running a Pro on the older Arlo base. All is 100% as to the Pro functions.
All u lose by not having the pro base is the siren and local record...
g33k3r
TomMac, thanks for the direct feedback on your use of the Pro camera.  I've seen "rumors" of the original base station receiving a firmware update to support local storage.  Either way, the audio portion is the most critical support with the camera. Thanks again, g33k3r.
Just a PS....there are still a few problems/ complaining about the audio on android phone, check the threads...Netgear was working on it
