Disable alarm on app
I'd like the ability to remove the "alarm" button from the main page of the app when using Arlo Pro cameras. I don't want to use the siren feature and am just worried I will accidentally hit it.
Ksly9,
Even if you accidentally tap the "Turn Siren ON" button, a second window will open prompting you to make sure you really want to initiate the siren feature. This is put in place to help prevent accidentally turning on the Siren.
You can also reposition when the base/siren shows up on the Devices tab.
