I currently have 5 Arlo Pro cameras. If I added a 6th camera and had it be a CVR camera, does anyone know if Netgear will double charge me? Ie pay for the CVR plan as well as pay for the Primere plan upgrade?
Yes. Those are two separate options.
Two separate options but I could be forced to get both?
You may choose to get both. No forcing. Some folks only want the ability to increase the number of cameras for cloud recording above 5 but don't want CVR. You get choose which options you need.
