Continuing and increasing frequency Arlo cams not detecting movement or recording
I am STILL having issues with cams not detecting or recording motion regardless of setting. They're set to 100%, app uninstalled and reinstalled, base and cams sync'd, and wifi signal is steady and good. The problem seems to be with Arlo and it's servers.
I was going to upgrade system and buy the cloud service but if I can't get this problem which is continuing and increasing in frequency solved, I'll have to go with another company.
Do you have a VMB4xxx base? If you do, you can add local USB storage - preferrably a thumb drive (16 GB or larger). That would let you rule out the Arlo cloud. Note you'd need to remove the USB drive and connect it to a PC to check for recordings.
You might also want to try the motion detection test, and see if it reliably detects your movement.
