Cons About The New Update
I hate this last update install. I hated the last one. But this one is even worse. So slow. No pause on live feed. Can't pause and play fast. Absolutely horrible. I'm switching to RING
8 REPLIES 8
Hi @1111me
Can you provide a bit more detail regarding the issues you are having? What are the circumstances in which they arise?
Ever since last update i get 2 notifications per action/recording. Frustrating. Turn off push notifications, i get none. Great. Then turn it back on & i get 2 push notifications from all my camers. Fix this.
What device/model/os are you using? What version of the Arlo Mobile App are you using?
LG, K20 Plus, Android ver 7.0, Arlo App ver 2.7.8_25585, Released 04/16/2019
I'm also getting double notifications on my Android phone. I have uninstalled and reinstalled the Arlo app. That didn't help any of my issues. Still as much $$$ as we paid for this security, we should be able to have all the control features at our finger tips as we did 2 updates ago. Put all the play, pause, record, etc buttons back underneath the frame instead of inside of it. If I can't freeze frame within a millisecond, the product is virtually worthless. I use to be able to do this on this same Android phone, same Arlo cams, 2 updates ago. It seems companies like to fix what isn't broke just to be doing something.
