black screen that says no connectivity
  • 1 Reply
  • 604 Views
Lsrry
What is the secret to connecting the camera after you charge the battery? All I get is a black screen that says no connectivity
All I need to do is reinsert the battery, and the cameras connect automatically.
Is this really with the old Pro camera?  If not, what model is your camera?
Did you let the battery completely discharge?  If you did, then charging the battery in the camera sometimes doesn't work.  You could try this procedure:
