Connecting Alro Home Security to another device
Hi
I Have Arlo Security system at home.
I was able to connects the system to one only device (iPhone 7). However, I can't connect it to another devices (iPhone x, iPad). How can i fix this problem?
Thanks,
Did you install the app on those devices and use your login credentials? Do you get an error message?
