Confused on the battery life
I have model VMS4330 of the Arlo Pro wireless HD camera that came with 3 cameras and 3 rechargeable batteries. I am confused about the batteries. I have recharged each battery one time when the battery life indicator indicated they were low. Now all of a sudden, I get "It's time to change your batteries" on all 3 cameras. Are the "rechargeable batteries" only rechargeable once???????
No but the length of time that a battery will last, whether in a camera or a flashlight, depends on how it's used. The total number of minutes of live viewinng and recording per day as well as how the WiFi signal between the base and cameras makes all the difference.
Hmmm... strange. What firmware version are your cameras on? I wonder if this is a message meant for the Arlo HD. Have you opened a ticket with support?
I haven't run my Pro batteries down to the point of complete exhaustion so can't be sure but I suppose it's possible that the software is programmed for only one response at that point. If that's the case, charging would be the same thing as changing.
