When I try to login as I have for years I enter my details and click login and nothing happens. When I inspect the page I find my login request is getting blocked by cloudflare. It is impossible to use my cameras at all. See screenshot- cloudflare is blocking my IP for some reason and they say to contact you.
Use https://my.arlo.com.
Arlo hasn't been part of Netgear for 5 years now, and arlo.netgear.com ends up redirected to my.arlo.com.
That said, you will find that arlo.netgear.com will still work - the /hmsweb/login suffix you are using is what is triggering the cloudflare action.
thanks that worked!
