Charging Percentage
  • 1 Reply
  • 1575 Views
FancyMonkey
Whenever I charge any of my 4 cameras, it doesn't seem to update my charging percentage. I will check it several time in an hour and the percentage goes up, but then an hour later it won't have increased at all. Turning it on or off doesn't seem to update. Logging in and out doesn't seem to help either. The only other thing that seems to update it is to take the battery out and put it back in. Anyone else having this issue?
Make sure the camera LED is turned on to show the battery is charged.  Does it light up when it's done charging (2.5-3 hours)? Maybe the charger or cable is bad and actually isn't charging.
