Charging Fault - Charging Fault Detected
  • 6 Replies
  • 3009 Views
Smaj1987
I am receiving this error “charging fault detected, unplug charging cord from camera side and try again.”
6 REPLIES 6
steve_t
Master Master
Are you using the genuine cable and charger that came with your camera? Third party chargers are often not compatible
Smaj1987
Yes, it is the cord that came with the device
steve_t
Master Master
And charger/adapter/power supply?
Smaj1987
No the power supply cannot be found, could this be the issue?
Yes, the factory supplied ac adapter is a Qualcomm type that supplies 5v and 9v to charge... A regular USB adapter will not charge the camera
steve_t
Master Master
Yep. As Tom said, the charger needs to be a specific type to charge the camera. If you have a Samsung fast charger, that might work but you're always best to use the Arlo charger. The majority of other USB chargers will not recharge the Arlo battery
