I purchased another base station to add more wireless cameras. I can't get the base station to set up. I tried the reset on the back of the unit and it still does not work. I may have messed it up by trying to set them both up with the same name, but I changed the name on my computer and it still doesn't work.
I removed both base stations and reloaded them. They work fine now. Thanks.
It sounds like your base is claimed but what are the LEDs on the new base showing? You should have at least the power and Internet LEDs showing green.
