Arlo Pro VMC4030 battery dead in less than 1 year?
I have 3 cameras running for less than a year. They are used very little (I think I've only recharged the batteries maybe 3 or 4 times), and the app is telling me that I have to change the batteries... is this normal?? I tried recharging, but they're not taking a charge. I read that I should try deleting and then re-adding the cameras- but that didn't work.
Thx
Yes, I'd found that page and tried but I still cannot charge the battery. No LED lights at all. I'm probably not using the micro charger that came with the camera.... assuming that they're all the same and I have many- I'm sure I have the wrong one.
But I'm having difficulty understanding why this is even happening? It's less than a year old- is it normal to have to play games with the battery to charge it?
Is this what I need - the VMA4800 ?
That's the right one.
