Cannot get proper help from Arlo support
  • 2 Replies
  • 2925 Views
Karimm
Hi there,
I could see my Arlo Pro (VMC4030) camera battery is draining and Arlo support generated RMA (7064367) . I send the camera to the location
(BrightStar Logistics Australia
Door 7 11-13 Ash Road, Prestons
NSW, 2170, Australia)
by AUSPOST and came to know that it has been delivered. I could see my old case is closed. Then I called Arlo asking them if they have received my camera for repair. Arlo support raise another case and I did not get nay response yet : rather getting some repeated machine generated emails. Now I am worried if the camera is lost! I could see Arlo support is soo bad in response.
Regards
Mohammad Karim
ShayneS
Hi @Karimm
Have you tried to contact customer support after the second case was made?  you can provide them with your current RMA or Case number & they will be happy to assist you.
Karimm
No I am happy with Arlo but not with Arlo customer support representative. Seems they don’t read my reply
