  • 4 Replies
  • 1929 Views
Laketrader
Another post mentioned something in upper left hand corner but I could not find it.
Laketrader
It's working now.  Apparently the upgrade was not  working at first.
Do you mean the mute notifications setting?  If os
  1. press the profile icon in the upper left of the screen
  2. select notifications (which should be right above "locations and plans"
  3. you should see "Mute Notifications" (should be right under "Home").
Laketrader
Thank you but I a talking about my Android phone.  There is nothing in the upper left hand area.
This is the same for both Android phones and iPhones.
Are you seeing "Library" in your app menu?  Or are you seeing "Feed" and "Dashboard" instead.  The "Feed" interface should show a profile icon on both Android and iOS.  This is shown on all the main screens (dashboard, feed, emergency, devices, and routines).
Laketrader
