Can use talk back Microphone only when connected to wifi. When using Tmobile data I can hear in the room but I cant talk to room icon shows connecting......... Others have same problem for months with no fix. Iphone, ,current software,, correct settings,, T mobile,, LTE. If this is not fixable maybe netgear should advertise that DATA two way communication not compatible with Tmobile Iphone LTE. Doesn't anyone at netgear have Arlo and Iphone on tmobile.
A fix for this went out recently that should resolve issues with the push to talk feature when using a T-Mobile device on a data connection. Please let me know if you continue experiencing any issues.
It sounds more like a TMobile issue than an Arlo one but can't be sure. Contact both TMobile as well as support here to see if the two can create a resolution.
dadzoid,
Engineering is currently investigating this issue. I will post an update when I have more information.
I have not yet purchased the Arlo 2, but I want to. The only barrier is that I have read " T-Mobile uses IPV6 where Arlo Pro uses IPV4" If so, I assume that I will never be able to "intercom" with an Arlo Pro 2 (connected to WiFi) and my t-mobile phone (over LTE network). Has anyone else discovered similar information?
Any update on this issue? Major disappointment about Arlo Pro right now.
I have the same issue. Microphone doesn't connect on my Iphone 6s via TMobile wireless network.
Wish I knew this before signing up with Tmobile and buying Arlo Pro system...
Please provide update when available. Thanks
