Would you know if the 2-way audio can be turned off?
Because sometimes, you wouldn't want the camera to record sounds because it could be placed near your room where very private conversations happen.
Yes... under SETTINGS ( in the Q and I would think the same for the PRO ) there are two toggles for Mic and Speaker ( on/off)
TomMac,
This is the same for Arlo Pro, two-way audio can be disabled within the device settings.
