Can't login
I’ve just updated the app and it will not load to login screen. I’ve reset phone. Delete and redownloaded app, what else can I do?
Try disabling both mobile data and wifi, and then re-launch the app. It should fail, saying there is no internet connection. Then turn data back on, and see if you can then log in.
There was a bug quite a while ago, where that procedure worked. No idea if that is still the case, as your issue might have a different cause.
