Can't get base to connect to internet
Can,t get arlo base to connect to internet.
Do i need to buy new base.
I had an older base appear to be connected (proper LED colors) but couldn't be set up in my account. A different base worked fine. You can try the reset procedure by holding the button for >10 seconds until the LEDs flash amber, release the button and let it reboot to see if that helps. If not, you likely have a faulty base.
