Can’t get base station online after power cut !
Hi
One of my base stations won’t show as online. (See pic) , all lights are green on the base station. Any ideas that don’t involve resyncing all cameras as I have nine all in different and high locations.
What’s that suppose to mean?
Power cycling the base should work.
You may also want to power cycle the router to which the base is connected.
Try and remove and replace the battery on one of your accessible cameras to see if that works. Not the answer you want if it does!
Failing that unfortunately you may have ti reset the base and resync the cameras.
