Can i use new Arlo pro 4 cameras on a Arlo pro base
can i use new Arlo pro 4 cameras on a Arlo pro base
If your base is a VMB4xxx model, then you can use a Pro 4. If it's VMB3xxx, it is not compatible. You'll find the part number on the base station.
