Ich würde gerne wissen ob die Arlo Pro Basisstation fest mit dem eingerichteten Router verbunden ist oder ob den Router bzw. Standort wechseln kann ohne Neuinstallation.
While there have been instances of having to redo the installation when switching routers and/or locations, you should be able to unplug from one and plug it into the other with no issues.
I would like to know if the Arlo basestation is only connected to the router where the installation was made with or if you can exchange the router or even the location without doing a complete new installation.
