Can a cord connecting the solar panel and the camera be longer than 6 feet? If so, do you sell one, or does someone else? Can two cords be attached together with no worry about the weather?
I could see an issue with volatge drop over longer small gauge wire..
That being said, you would have to come up with your own methd of waterproofing as no cable I'm aware of is built with the sealing plug they use.
