Can I use 240 volts adapter for Arlo Pro?
I bought an Arlo Pro camera and I wonder if I can use an adaptor for 240 volts with it.
The camera itself uses 5v to run and 9v to charge over a microUSB cable. You would use the appropriate USB charger or a plug converter.
