  • 1 Reply
  • 759 Views
waha1022
My Arlo Pro camera will not charge or work on AC power only. It has worked well for a couple of years now but recently I got warning that it was off-line but was plugged in to power. I checked to make sure power was getting to the camera. I brought the camera in my house and it worked fine on both battery and power only. I have replaced the power cord feeding the Arlo power adapter. Tested the power adapter on another camera. And again today I got a message the battery can't be charged, and there is no battery in the camera. It is on power only. It is an H8 camera with firmware 1.092.1.0_9_120d8b7
Dannybear
Sounds like a problem with the arlo app. Tried reinstalling it?
The pro 4 will not work with the VMB3xxx series Base station, although it can connect directly to your wifi network, subscription required though.
