Can I Secure the Camera To My House?
I see that the magneic base makes for easy installation but whats to stop someone from removing the camera from the base? Do they have a permenent mount for outdoor installation?
Did you check the product accesories from the menu at the top here? There are various Arlo threaded mounts as well as a zillion on AMazon. These cameras all use 1/4"-20 threads.
At $200 per camera I would think that something more than a magnet would be supplied to secure it to the house. Their system works just fine for indoor installation.
So use one of the threaded mounts available from Arlo or many other suppliers.
