Arlo knows this is a problem and won’t do anything about it. I was moved from tech support to Ecommerce support yesterday and when I asked to speak to a manager or executive the agent ended my chat. This product has gone from a good product I would recommend to absolute garbage. After spending hundreds or maybe $1k on cameras and subscriptions I feel forced to trash these things and go buy a ring system.
Arlo please help!!!!!
It sounds mostly like a signal strength and/or quality issue. What happens if you bring a camera closer to your base? Does it always work then? If so, try moving your base away from your router and look for other wireless devices nearby that could be interfering with the signal.
Edit:
If detection was working but no video are recording to the cloud library, check the subscription plan if you have one has not expired.
Hi, thanks for the suggestion. They are not, they are battery powered. But it is one thing I told support which they never responded to. I changed batteries to a different brand of rechargeable batteries. It is the only change I made to the set up during while this has occurred. I suppose I could buy some new batteries and test that. Do you think that could cause the issue? Thanks again!
You can reset the pro2 cameras by removing the batteries for ten seconds and reinstall.
Depends if you’re getting notifications of motion detection, have you?
How can I tell what version of cameras my original card are? I think I got them at Sams club.
Thanks so much. You’re more help than Arlo!
Edit:
https://community.arlo.com/t5/Arlo-Pro-2/How-do-you-determine-if-you-have-Arlo-Pro-or-Arlo-Pro-2-cam...
I have 4 cameras. The 2 that are the ULTRA model suddenly stopped recording. I have made no changes to settings or modes and don’t have problems with my other older Arlo cameras. I have removed and resynced but they only allow me to view LIVE video and the record tab isn’t checked (won’t allow me to check) so I can’t record
Did you get a fix for this?
The Ultra cameras require a subscription to be able to record to the arlo cloud library.
The cameras pro2 or earlier came with the 7days free cloud storage feature.
Camera models after that (2018) require a paid subscription plan although arlo used a free trial period to get you started.
Thank you. That’s unfortunate because it was one of the main reasons I bought two more Arlo cameras.
You do have an option to record locally to the base station backup USB on the 4000 and 4500 base stations and the 4540 and 5000 units enable app access to local storage for viewing with limitations of course.
No I never got this fixed. I still have to reset the base station regularly to get the recordings to work again. But that doesn't last long. I'll never buy Arlo cameras again. I'm moving in with my Fiancée soon and will add on to her Ring Doorbell with other Ring products. I know technology changes, and with it support for older products goes away, but these cameras are not very old. And for Arlo to pretend like this isn't a common issue is disappointing.
We have five cameras that are all still communicating with the Arlo Secure app. I can connect to them at any time and see live video. They simply fail to turn on when triggered and record a video. We have contacted customer service and we can't get a response. What happens if I do a factory reset on this system? It certainly can't get any worse than what we have right now which is nothing. We pay the $9.99 fee each month also.
Can you confirm that you are able to manually record to the cloud library when you live view a camera and if so is the camera armed for the mode setting.
If you have a subscription you can access personal support from the app settings page.
Also, check Settings, Subscription, Manage Cameras to ensure that all cameras are enabled in your subscription.
