Cameras operating but library showing no recordings
Camera is working. Library recordings empty. Powered off, library recordings populated for an hour or so. Logged back in, recordings empty.4VR16B7UA3D74
Check if your SW versions are up to date.
Notifications okay, visible umber of recordings on front screen also works, but when access to library, empty on all 5 cameras
Power cycle the base. Use both the app and a browser. If no good, contact support to open a case.
Hardware h7 no updates available.
Bpmertz,
If you live stream and manually record, is a library recording produced?
Also be sure when checking your library no filter is applied.
When I do a live recording a library file is created. After a day, it dissapears. I was on with the on-line chat. They has me power off and do a live recording. Everything dissapeared within a day.
When I first got my unit- it worked fine for a couple of weeks.
Dear James.
i just tried manual recording and yes, it was visible in the library.
i looked at the filters, they are all checked so it should show everything, I assume...
the crazy thing is, when I open the app the small recording indicator in the top right corner will tell me there is 12 recordings for that specific camera, when I access the library it's empty, AND when I return to the overview screen, the number has changed from 12 to 0.
i have had the system for 6 months, five cameras no problem, until January 28th . No changes were made to the system, my wifi or my subscription.
Per
Hi Bpmertz
i just realized that the email notifications I have received has a date marking of dec 12. Even though it's a 2 minute old recording.
s that the same for you?
i have looked for a place to change time and date but can only find a place to insert an automated region based time zone,
Does anyone know where Arlo pick up the time and date information?
Per
Seemed like the system had a wrong date, since the library only contains 1 week and the date was one month earlier the recordings dissapered.
I chancer time zone and rebooted the system, problem solved
Per
The dates on my push notifications are spot on.
