Cameras not wanting to load after battery change
  • 1 Reply
  • 1184 Views
Ponyboy1963
Everytime I change batteries it takes at least 1hr of my time. You run tests and they get worse. You call Luke you care but when we call back it leave you dont call. If I could we would be in court.
Why dont you fix, repair or replace. That's what good businesses do.
You want us to buy your items but you dont fix problems.
If you fix things and they worked. I would buy more.
I did like Arlo for a little bit.
Now it's like you dont care.
Fix, repare or replace. I've had nothing but problems.
Why dont you care.
JessicaP
Hi Ponyboy1963,
When you mention that your cameras are not loading, are you referring to viewing the live stream from your camera? And what camera do you use?
You can refer to this article to learn how to extend the battery life on your Arlo camera: How can I extend my Arlo camera's battery life?
