Cameras not recording at night. Not on schedule. Tried resetting but stops recording at night.
I have had 3 Arlo Pro wireless cameras for about 2 weeks. They were great the first few days but then they all stopped recording at night. They are not on a schedule so they should be recording 24/7 like they were in the beginning. I took them all down and reset each camera and then they started recording all day and night again. But then after a few days, they stop recording at night. Any ideas on what I can do to fix the issue?
Hey SabrinaP,
If you're using custom mode, try testing on "Armed" mode to see if that helps. And you can delete your custom mode and re-create the custom mode again to see if that resolves the issue.
