I have an Arlo Pro 2 system with 5 cams. They are all set to record clips when motion is detected. Two days ago, one of the cameras stopped recording any clips. I can still view the live image, just no motion detecting or clips recorded. All other cams work fine. I tried removing these battery and re-syncing but that didn't fix it, and I have the motion sensitivity at 80% like the other 4 came. Any idea how to fix this issue?
Are you using the default Armed mode or a custom mode? Check the rules within your active to mode to make sure that the camera that is behaving incorrectly is set up to record when motion is detected.
