Camera says offline when it is connected to WiFi.
It says its offline. It was fine for a year, but not it started to be weird for some reason. The baterry is charged. It works sometimes and then it doesn't. I have attached image.
Hi @Karolina
Have you tried to remove & re-insert the battery to the camera? You can also try & remove the camera from Settings > My Devices > Re-add it & test again.
