  • 1 Reply
  • 1312 Views
Whitey80
Camera records upside down & one doesn't record
A little more info would be helpful - camera models, base station, whether this is a new install, or something that just failed.
On the upside down recording: there is a setting that rotates the video 180 degrees that you should check.
On the one that doesn't record:  Does it live stream?
