In order to assist you, we need a lot more information from you.
Art the cameras Pro models?
Are they inside cameras or outside cameras?
What were the conditions when the camera went offline?
Are you sure the battery has a sufficient charge and is making good connection with the contacts inside the camera?
Have you tried to open the battery door to the camera to power cycle it?
Have you tried to re-sync the camera?
What are the lights on the hub showing when you try to re-sync it/
Brian
Take the battery out and put it back in. What color LED blinks on the front of the camera?
It's likely a one time occurance of unknown origin. I turn my various cameras off at will with no problem. It would be better to test it to verify proper operation than to ignore the issue. A bad camera can be replaced.
