Camera not charging battery, swapped batteries around between cameras still not charging - no succes
Have 4 Arlo Pro cameras, one is indicating the battery is not charging - all are constantly connected. I've swapped the batteries around but still having the same issue with the same camera. Swapped charger and lead, still no success - any suggestions?
Hi @Adapttc
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
