Camera keeps going offline. Removed battery but stays online momentarily.
  • 1367 Views
Chiefsnell
Cameras (3) keep going offline, I have removed batteries an it only stays online momentarily. The other cameras are online and working fine (2) are indoors not far from WiFi base and one mounted above the garage door. Help I am tired of dealing with this issue!
What is the signal strength to the cameras going off line?
Since the others that are closer to the base seem fine, then it may be signal and/or interference at a proximity near/between the troubled units and base
Chiefsnell
The signal strength seems to be strong and closer to the base than the others currently online.
Swap cameras around to see if it's the cameras or the locations.
