I delete the app, reinstall, get to the main screen, try to view a live feed, third camera shows an old view and then goes offline, and then app crashes. I turn phone off and on, reopen app, app crashes. Also, my third camera is already at 55% battery life while the other two are in the 90% range.
Running app on IPhone X with Verizon LTE. Home WiFi is Comcast. App says it’s up to date. I’m assuming the firmware on system is up to date as well (I don’t know how to check).
I paid like $400 for this system on Amazon last week and I am already having issues. Any suggestions?
Hello @Dan050812
Are you using FaceID on your iPhoneX? There appears to be a known issue with this feature causing some apps to crash. We are working on this issue on our end, however, disabling this feature in the meantime should resolve the issue with your app crashing.
Dawn Marshall
Arlo Community Manager
Have you attempted a reboot of the base unit ( power button off-on ) ?
If that doesn't work/make any change, before you go farther, I would test your system on a computer ( to eliminate the posssible phone issue ) as it may not be your end.... https://arlo.netgear.com/ ( use your email/pw you do now )
If it works on the computer, then the phone is somehow causing and issue... will wait for a reply before advising more
Hello @Dan050812
Dawn Marshall
Hi
i think his is an app issue, as if you log in online on a computer I bet all your cameras are perfectly working and online!!
i have a second base station as since 2.5 update the second base is showing as offline when it’s not! A real pain as if messing up my geo fencing and can’t view all the cameras to the second base!!! I do have an iPhone X with firmware 11.3.1
I am having same issue. All cameras work on computer as well as on my wife's Iphone 8. However on my Iphone X cameras linked to second base always say "offline". How do we let netgear know about this issue so they can update app?
