I have 1 alro pro camera installed outside and base unit. What camera model/s can I purchase
to add to the inside of my home?
Either of the wireless camera models (original and Pro) can be added to your system. You can also use a Q camera although it uses only your home WiFi and not the base so it would need to be configured to be used as a separate system and not part of the wireless cameras.
I went with the Arlo Q for inside. It appears on the same computer/phone screen as your Pro camera. It can also be plugged into a wall for power.
